Kunena 7.0.8 Released
This category is only for reporting defects or problems with Kunena 1.6 test versions with Joomla 1.6. This is NOT a support forum - there is no support for test versions. Users should NOT install K 1.6 alpha or beta test versions on websites with live production data.
Question Upgrade error JAccess on front end
15 years 10 months ago #65025 by Slotpro
Hi
After upgrade kunena 1.5.6 to 1.6 have error on kunena page error text below
Fatal error: Class 'JAccess' not found in /home/www/virtual/xxx.com/htdocs/administrator/components/com_kunena/libraries/integration/joomla16/access.php on line 113
15 years 10 months ago #65067 by xillibit
Thanks for report, can-you put here please your kunena configuration settings ?
15 years 10 months ago #65283 by piligrim
I have this problem to.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 30M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.6.285) | UddeIm: Disabled or not installed
15 years 10 months ago - 15 years 10 months ago #65311 by xillibit
1°) Joomla! 1.6 is still in beta and is a moving target, so we are waiting something which in stable to start look the issue on j! 1.6
2°) You are using J! 1.5 but the integration -> access control is trying to load a joomla class which is only present in joomla 1.6, this is weird
Last edit: 15 years 10 months ago by xillibit.
15 years 10 months ago - 15 years 10 months ago #65978 by Wasuup
I've just migrated from Kunena 1.5.11 installed on Joomla 1.5.21 and have exactly the same issue. If Kunena 1.6 isn't being looked at for bugs then why is it trying to use J!1.6 ACL on a J!1.5 installation?
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 12M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Last edit: 15 years 10 months ago by Wasuup. Reason: updated config
15 years 10 months ago #65983 by fxstein
Clearing up some confusion here:
Kunena 1.6.x is very actively being worked on
BUT
Support for Joomla 1.6 is currently not as Joomla 1.6 is only in beta and things are changing from Beta to Beta
Once Joomla 1.6 goes to RC, we will fix any Joomla 1.6 related issues and bugs.
Time to create page: 0.267 seconds
