Question KunenaLatest Topic first post
15 years 7 months ago #91573
Replied by sozzled on topic Re: KunenaLatest Topic first post
G'day, Krumz, and welcome to Kunena.
There is an unwritten rule in online forums that says "don't hijack someone else's topic". In other words, when you post a question that is completely different to the question that someone else asks, dont!
The fact that when the Kunena Discuss module shows "the most latest posts as it should but when I login to the forum - the posts go away and it says there are no post to display" has nothing to do with this topic. It's off-topic. Please look at Kunena Discuss (P) and see if your question has been asked and answered elsehwere. I think it has.
Thank you.
Thank you.
The following user(s) said Thank You: krumz
The topic has been locked.
15 years 7 months ago - 15 years 7 months ago #91574
mikefriendly: sorry about that interruption. Let's get back to your problem.
There is an easy way you can do this without using the Kunena Discuss module and I'll show you how.
Did you fix your legacy mode and database collation issues? Are you satisfied with our answers?
- Go to Forum Configuration » RSS » RSS Settings » RSS Feed type = By topic
- Click the RSS Icon at the bottom of your forum page and make a note of the URL. It will look something like http://<your-domain>/forum/rss?format=feed.
- Go to Module Manager and add a New module of type Feed Display. Give your module a Title and assign it to a module Position on your site template. You can also tailor how many words to display in your feed module.
Last edit: 15 years 7 months ago by sozzled.
The following user(s) said Thank You: mikefriendly
- mikefriendly
- Junior Member
- Thank you received: 1
15 years 7 months ago #91586
by mikefriendly
Replied by mikefriendly on topic Re: KunenaLatest Topic first post
Thanks for this sozzled, it sounds like the answer to my troubles!
I'll try it later and attend to those issues as well...
- mikefriendly
- Junior Member
15 years 7 months ago - 15 years 7 months ago #91743
by mikefriendly
I hope it is ok to add this to this thread!
I am trying to turn off legacy mode as advised and have removed PuArcade which I know needs it and causes problems.
When I turn off the System - Legacy plugin then I get the message:
Direct Access to this location is not allowed.
So I have it turned on still!
I have Googled this and tried a few of the tips but to no avail.
Any ideas please?
Any ideas please?
Last edit: 15 years 7 months ago by mikefriendly.
15 years 7 months ago - 14 years 7 months ago #91747
by xillibit
Replied by xillibit on topic Re: KunenaLatest Topic first post
Update AUP to latest version, you are using maybe an outdated CB plugin which require legacy mode
Last edit: 14 years 7 months ago by sozzled. Reason: Change topic icon
- mikefriendly
- Junior Member
15 years 7 months ago #91770
by mikefriendly
Thanks for the tip xillibit. I have upgraded AUP but when I turn off the System - Legacy plugin I still get the
Any other ideas or is there anywhere I can find a list of plugins and components that use Legacy mode that I can remove from my site?
