Question Unreaded Post only
15 years 7 months ago #91144 by MfGLucker
Unreaded Post only was created by MfGLucker
Hello Kunena Team, i want to link in my 1.6.3 forum only New Posts.
Better explaining
Forum usage normally, on other place ( Modul with link to profil and so on ) at startpage i want to set a link to
"unreaded post only"
Is it somehow possible with kunena to display only "unreaded Posts " only, after klicking on a link ?
And if I read this posts, after klicking on this link again, it should be not shown again, until a new post followed
p.s.
I´m totally new to Joomla and Kunena.
Joomla 1.6.1
Kunena 1.6.3
Link to page www.mfg-lucker.de
It´s still under construction, and if i found a solution for every function my community needs, this page will go online under mfg-esports.com ( until now phpkit :sick: )
I postet this Post first in wrong category i think, i hope i get here an answer
Sammle erst die Fakten, dann kannst du sie verdrehen, wie es dir passt.
Mark Twain
The topic has been locked.
15 years 7 months ago #91166 by sozzled
Replied by sozzled on topic Re: Unreaded Post only
No, there is no way to display only unread topics and nothing else.
I use the Recent Topics view for viewing unread topics and it method works fine for me in this forum.
This is as good a category as any to ask your question. I hope my answer helps.
15 years 7 months ago #91173 by MfGLucker
Replied by MfGLucker on topic Re: Unreaded Post only
This is not the answer i hoped to become here, but thanks for your quick answer, we used the unread only function in phpkit very often, hmmmmm
I try to find another solution for this problem
Mark Twain
15 years 7 months ago #91175 by sozzled
I don't know what phpkit is. Kunena is Kunena. Kunena does not have the same feature set as other web-based discussion forum software (and other products don't have the same features as Kunena, either) and that's good. It would be rather dull, wouldn't it, if every forum product did everything that all the others did?
15 years 7 months ago #91176 by MfGLucker
please, dont understand me wrong, i dont wanna find an other forum solution,because i have already importet nearly 31000 postings from this phpkit forum to my kunena installation.I try get my community away from this phpkit cms, with very simple forum. It was a lot of work to explain the forum functions to them. And now, comes a new forum , you know what i mean ? So, i just want to keep the explanation as small as possible :-)
But if there is know way to do this with kunena, no problem.
I will explain it to my community. I just wanted asked this question, and i get your answer.
Mark Twain
15 years 7 months ago #91186 by sozzled
I can only repeat the advice I gave earlier. This feature that you want is not currently available in Kunena and there are no plans to develop this feature at the present. I suggest that you use the Recent Topics view to see what messages are unread; that's what I do and it works satisfactorily for most people.
