- Thank you received: 3
Question Define moderator per (unmoderated) category
Yes, I am aware that an admin can define both global moderators and moderators per category. BUT...
The latter only works for moderated categories.
There seems to be a terminology issue here: "moderate" is being used in Kunena for two different tasks:
- Pre-approve posts
- Manage existing threads
At the moment, Kunena almost supports this.
If you define one or more users as moderators (#2 above) for a given category, their names are displayed as such at the bottom of the category index. So far, so good.
However, if the category is unmoderated (#1 above), this overrides the moderator (#2) settings.
See how confusing this is?
Moderator names shouldn't be displayed if the (non-global) moderators can't manage existing threads.
I would be really grateful if this overriding behaviour could be disabled (or at least be configurable). I would be even prepared to contribute a bounty if any of the devs are interested.
"Pre-approve" posts. Now that's a different subject. I think that this relates to the "Review posts" option. If you want review posts in an unmoderated category then you need someone to review and approve the posts; that's where you need moderators (global moderators and administrators). It seems a little incongruous to me that you would have categories defined as Review posts = Yes and Moderated = No.
Have I missed something here?
You have it precisely backwards. I am trying to set up Review posts = No and Moderated = Yes.It seems a little incongruous to me that you would have categories defined as Review posts = Yes and Moderated = No.
I want to assign moderation tools (delete/move/merge) on a per category basis rather than globally. I am not interested in reviewing my users' posts in advance. They can post whatever they want.What specific privileges do you want "moderators" of unmoderated categories to have?
My apologies for not explaining things better.
You wrote above that you have 15 "unmoderated" categories. I guess it's a difference in our understanding of what you mean as unmoderated categories. Do you mean that you have 15 categories with Moderated = Yes, to which you would like to assign moderators but haven't as yet? Have I correctly understood your question?
You posted this in the "feature request" category; I'm trying to understand what specific missing feature you would like to see implemented.
In the admin pages, under User Manager, it is straightforward to assign moderators to specific categories.
Their names are then displayed at the bottom of the respective category index pages.
So far, so good!
However, if these categories are defined as unmoderated, meaning there is no prior approval required for posting, then the moderator tools are not available to the so-called moderators.
My wish would be for it to be possible to disable such behaviour: to allow moderation tools to be assigned on a category basis.
If this still isn't clear, I will try to explain it in a different way. Thanks for your patience.
Can we not use the word "unmoderated" in the sense of Review posts = No, please? I know, there's no simple English word that otherwise describes what you are saying, so I use the literal phrase "in categories set with Review posts = No" because it's unambiguous what we both mean.cbrace wrote: However, if these categories are defined as unmoderated, meaning there is no prior approval required for posting, then the moderator tools are not available to the so-called moderators.
Summarising the situation:
(1) You know how to assign moderators to individual categories. Good.
(2) Your categories (all 15 of them) are defined as Review posts = No, Moderated = Yes. (This is fairly typical, by the way.)
(3) Your assigned, category moderators do not have moderator privileges (e.g. edit, delete, move topics/posts). That's not normal and it sounds like there's something amiss on your site. Do your global moderators have these privileges?
If my suspicions are correct, this does not seem to be so much a "feature request" as it is a request for help. Please post your K 1.6 configuration report. Thank you.
