Question No frontend access
15 years 8 months ago #89623 by AbdRahim
Replied by AbdRahim on topic Re: No frontend access
sozzled: Same result 404 error page not found. What file points to the kunena menu and where should it be? How do I change the pointing file to point to the correct place?
15 years 8 months ago #89635 by 810
Replied by 810 on topic Re: No frontend access
Fixed:
The problem is the: Use Apache mod_rewrite.
So you have a problem in your .httaccess
regards 810
The following user(s) said Thank You: AbdRahim
15 years 8 months ago - 15 years 8 months ago #89664 by AbdRahim
Thanks 810. Can you tell me how to fix it?
Last edit: 15 years 8 months ago by AbdRahim.
15 years 8 months ago #89665 by sozzled
15 years 8 months ago #89713 by AbdRahim
Thanks sozzled and 810. It turns out that the rewrite was pointing to the folder in which Joomla was originally installed. I have since moved it to the root folder. After changing the reference in the .htaccess file to the root folder the forum showed up. Thanks much.
