Question No frontend access
15 years 8 months ago #89599 by AbdRahim
No frontend access was created by AbdRahim
When I try to create any Kunena menu item, I get 404 error -page cannot be fount. Cannot see the kunena menu outside of the Joomla back end.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
15 years 8 months ago #89602 by 810
Replied by 810 on topic Re: No frontend access
There is no menu. Please click on kunena backend. On "create menu".
regards 810
15 years 8 months ago #89603 by AbdRahim
Replied by AbdRahim on topic Re: No frontend access
Did this. There is a menu seen in the Menu manager, but nowhere to be found on the front end of the website.
15 years 8 months ago #89606 by 810
Can you create me a super administrator account, then i will take a look. Please send it by pm.
regards 810
15 years 8 months ago - 15 years 8 months ago #89607 by AbdRahim
ok. Don't know if this helps, but I can only get to the login page of the forum if I attach the link info to the end of my url.
www.myurlname.com/index.php?option=com_k...=post&catid=0&do=new
Last edit: 15 years 8 months ago by AbdRahim.
15 years 8 months ago #89613 by sozzled
Time to create page: 0.216 seconds
