Question Profilebox removal not working here
15 years 8 months ago - 15 years 8 months ago #87463 by MrBlonde
I'm trying to remove the profilebox in Kunena 1.6.3. I've tried doing what's recommend - Login and Registration => Integration => None, but this has not made a difference.
I'm using 810's NEW v2 template if that helps at all.
Any help appreciated!
Here's my settings :
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : rt_afterburner_j15 | author: RocketTheme | version: 1.5.0 | creationdate: 08/07/09
Kunena default template details : New V2 | author: 810 | version: 1.6.0 | creationdate: 2010-10-23
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3.1) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Last edit: 15 years 8 months ago by MrBlonde.
15 years 8 months ago #87482 by sozzled
I wonder what made the difference? :side: Oh well, the problem is solved and that's what is important.
15 years 8 months ago - 15 years 8 months ago #88593 by MrBlonde
Nope, not a clue here either - like most things with K1.6 and my site at the moment :S
15 years 8 months ago - 15 years 8 months ago #89735 by Takkie
I've been searching several hours to solve this issue I'm having as well.
This box has to go, but can't find a way. And I do not want to mess up the code.
Can somebody tell me how to remove the profilebox?
I have already tried setting all the options in Intergration tab to none without good result :(
Last edit: 15 years 8 months ago by Takkie.
15 years 8 months ago #89738 by sozzled
G'day, Takkie and welcome to Kunena.
Can you please post your K 1.6 configuration report so that we can see what, exactly, are your configuration settings. Thank you.
15 years 8 months ago - 15 years 8 months ago #89747 by Takkie
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : hidden | author: hidden | version: hidden | creationdate: hidden
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Somehow in the Aphotic (and the default) template, the minimize button to collapse the profile box was not visible due to the -16px margin in the css file. Unsure why that is, but glad I found that for part of a solution.
I still rather have the entire profilebox gone. Or have it collapsed by default.
Time to create page: 0.170 seconds
