Kunena 7.0.8 Released
Question hi again, I got two questions mates. :)
15 years 6 months ago - 15 years 6 months ago #86027 by readyman
sozzled wrote: Joomla SEO:
* Search Engine Friendly URLs: Yes
* Use Apache mod_rewrite: Yes
* Add suffix to URLs: No.
* Rename htaccess.txt = .htaccess
Simple. Have you done that?
Yes I have.
I have done it in Joomla>ACP>Global Configuration>SEO
I have also enabled Joomla's SEO in Joomla>ACP>Components>Kunena Forums>Configuration>SEO Settings
Last edit: 15 years 6 months ago by readyman.
15 years 6 months ago #86030 by sozzled
As far as Kunena's configuration settings are concerned, I hardly ever change anything. I just use the Kunena defaults (except that I change the board title).
Have you tried setting Kunena configuration back to Default settings? (There is a Default button, top right corner of Forum Configuration page)
15 years 6 months ago #86037 by readyman
Yes I tried reverting it to defaults, still the same thing. :)
15 years 6 months ago - 15 years 6 months ago #86038 by sozzled
You've got an issue with the way that you have setup your Joomla menus.
Suggestion: remove all Kunena menus, remove all menus and menu items that link to your forum. Trash them; delete the trash. Use Create Menu function on Kunena Control Panel. This does not always work - it depends on your Joomla site template - but I like to keep the process simple.
This process is also explained in [Merged topic] How do I restore my Kunena menu?
Last edit: 15 years 6 months ago by sozzled.
The following user(s) said Thank You: readyman
15 years 6 months ago #86147 by readyman
Thank you sozzled, for now I will deal with it, later after work I will try your idea. :)
15 years 6 months ago #86561 by readyman
sozzled wrote: You've got an issue with the way that you have setup your Joomla menus.
You are the man my friend thank you. I didn't even think of this proccess :P
Cheers mate!
