Solved Default Menu Item in Entry Page is pointing to missing or unauthorized menu item
I've made a clean new install with 1.6.3 after deleting all files & DB of 1.6.2
Re-installing old DB
All is OK
Maybe conflict in config DB, don't know what happened....
- nelicopterr
I'm sorry to bother you, but I am having rather a few issues with the forum.
I installed the template on the forum and all was fine. I had no problems.
But then all of a sudden I got a notice saying:
"Please check your Joomla menus: Default Menu Item in Entry Page is pointing to missing or unauthorized menu item."
Underneath there is another notice which says:
"Undefined variable: fireonline in components/com_kunena/template/Euro-Lila/pathway.php on line 93"
I have included my report configuration settings:
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 30M
Joomla default template details : phoca_color | author: Jan Pavelka ( www.phoca.cz ) | version: 1.0.1 | creationdate: 24/02/2011
Kunena default template details : Euro-Lila | author: Mizunga | version: 1.6.1 | creationdate: 2010-12-20
board_title Forum board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template Euro-Lila showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 1 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login auto integration_avatar auto integration_profile auto integration_private auto integration_activity auto boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 1 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0
Try to re-create Kunena menu by using the function in Kunena configuration panel.
Use an another template or check if this template has been updated because this one seems to be broken.
- nelicopterr
500 - An error has occurred.
Another menu item has the same alias in Root. Root is the top level parent
Return to Control Panel
Call stack
# Function Location
1 JAdministrator->dispatch() /web/others/intranet/administrator/index.php:47
2 JError::raiseError() /web/others/intranet/administrator/includes/application.php:164
3 JError::raise() /web/others/intranet/libraries/joomla/error/error.php:215
Errors
The database row is empty.
Information
Backtrace
Call stack
# Function Location
2 JComponentHelper::renderComponent() /web/others/intranet/administrator/includes/application.php:153
3 require_once() /web/others/intranet/libraries/joomla/application/component/helper.php:156
4 KunenaModelInstall->deleteMenu() /web/others/intranet/administrator/components/com_kunena/admin.kunena.php:544
5 KunenaModelInstall->deleteMenuJ16() /web/others/intranet/administrator/components/com_kunena/install/model.php:1699
6 JTable->load() /web/others/intranet/administrator/components/com_kunena/install/model.php:1705
Information
Backtrace
Call stack
# Function Location
4 KunenaModelInstall->createMenu() /web/others/intranet/administrator/components/com_kunena/admin.kunena.php:545
5 KunenaModelInstall->createMenuJ16() /web/others/intranet/administrator/components/com_kunena/install/model.php:1392
6 JTable->load() /web/others/intranet/administrator/components/com_kunena/install/model.php:1577
Information
Backtrace
Call stack
# Function Location
Create an menu item called "Entry Page" as the title.
Make the Menu Item Type "Entry Page" from the Kunena section of the selection box.
under the Required Settings dropdown.
Choose a random Default Menu Item. It doesn't matter what you pick.
Save and close.
Click on the Entry Page menu item you just created to edit it.
Go under the required Settings dropdown.
You should now have, as an option under the kunena menu section an option for Entry Page. Choose it.
Save and close.
Your error should be gone the next time you reload.
--ja
