Solved Default Menu Item in Entry Page is pointing to missing or unauthorized menu item
15 years 9 months ago - 15 years 8 months ago #84077 by Nio
Please check your Joomla menus: Default Menu Item in Entry Page is pointing to missing or unauthorized menu item.
Joomla 1.6
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 512M
Joomla default template details : jt001_j16 | author: JoomlaThemes.co | version: 1.6.0 | creationdate: January 15, 2011
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Disabled or not installed
Last edit: 15 years 8 months ago by sozzled. Reason: Changed subject to improve relevance for search purposes
15 years 9 months ago #84088 by Nio
anyone???
15 years 9 months ago #84118 by Xav
same problem for me....
Upgrade 1.6.2 -> 1.6.3 and only admin can see the forum. No more categories for Members... :unsure:
15 years 9 months ago #84133 by xillibit
You have no kunena menus, please create it by using the function in Kunena control panel
15 years 9 months ago - 15 years 9 months ago #84138 by Xav
Hi !
it doesn't change anything.... with a new kunena menu
Public & Members can't see Categories, event when they want to post a new subject.
Loggin in Admin, all is OK....
I've made a new install after uninstalling the 1.6.2 version, and the problem is the same !
My Configuration report :
confidential]Joomla! version: Joomla! 1.5.22 Stable [ senu takaa ama woi ] 04-November-2010 Platform: Apache ( www.xgonin.ch ) PHP version: 5.2.17 | safe_mode: Off | register_globals: On | mbstring: Enabled | GD: bundled (2.0.34 compatible) | MySQL version: 5.0.84-log[/confidential]
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled | htaccess: Missing | PHP environment: Max execution time: 10 seconds | Max execution memory: 96M | Max file upload: 300M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 1.2 | creationdate: 02/02/10
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Last edit: 15 years 9 months ago by Xav.
15 years 9 months ago #84224 by Xav
Any ideas ??? :huh:
Time to create page: 0.172 seconds
