- Thank you received: 10
Question Full Screen Pictures Problem in 1.6.2
810 wrote: Next try.
Disable jcemediabox in Plugins
Next Advice pls the JCE Media Box is disable now
Kunena uses 2. One of them is Mootools 1.2.4; the other one is for the lightbox effect.
So, all you have to do is find out which one of the other 12 Javascript libraries is interfering with the Kunena lightbox display and you've solved your problem.
Hurr1c4n3 wrote: I think I know what the problem is. I allready posted it in another threat but got no reply on it. Your picture names have spaces in them. When they have spaces the lightbox doesn't work. I presume it is an old threat that has allready be posted. When you post a new message with pictures now the space is removed in the filename so the popup will work.
Yes, that's it Thank you for your perfect tip
Great!
