Question Full Screen Pictures Problem in 1.6.2
15 years 10 months ago #79475 by Masoud
I recently Upgrade my kunena 1.6 to 1.6.2
After the upgrade thumbnail pictures shows but when I click on the thumbnail / image link the full screen is just white
here is the a sample:
www.cyberg.ir/index.php?option=com_kunen...&id=61655&Itemid=118
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 24M | Max file upload: 100M
Joomla default template details : rt_zephyr_j15 | author: RocketTheme, LLC | version: 1.5.1 | creationdate: August 9, 2010
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.6.2 | creationdate: 2010-12-29
Kunena version detailled: Installed version: 1.6.2 | Build: 3894 | Version name: Team | Kunena detailled configuration:
Third-party components: AlphaUserPoints: Installed (Version : 1.5.12) | CommunityBuilder: Disabled or not installed | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.1)
Modules: Kunena Latest: Enabled (Version : 1.6.0-RC2) | Kunena Stats: Enabled (Version : 1.6.0-RC2) | Kunena Login: Enabled (Version : 1.6.0-RC2)
15 years 10 months ago #79491 by 810
hello,
i think its a conflict with the footer, can you disable that in the Rockettheme template. and try again.
15 years 10 months ago - 15 years 10 months ago #79494 by Masoud
810 wrote: hello,
Thank you for your reply
I've disable the footer but nothing happen.
Please be mention that when I inspect the image box in view mode via Firebug I can not see any image url in generated code.
Thank you for pursuing, and please be mentioned I've had this problem after upgrading to .6.2 version
Last edit: 15 years 10 months ago by Masoud.
15 years 10 months ago #79501 by 810
Please disable JCH_Optimize, and try again, and clean your cache, when you disbled it.
regards 810
15 years 10 months ago #79503 by Masoud
before I sent this message I've disable JCH and clean cache for several times, but problem did not solve.
Moreover the com_kunena component is in exclude list of JCH.
15 years 10 months ago #79505 by 810
Next try.
Disable jcemediabox in Plugins
