Question How do I enable quick reply?
15 years 10 months ago - 15 years 10 months ago #80574 by vientogris
I had the same problem than you plus another one, the bbcode toolbar was gone if polls were active (I was going crazy with javascript, mootools, etc).
Now I have disabled the Legacy mode plugin and all works fine now!
Thanks sozzled for your answer
edit:
1. Disabling Legacy mode solves my polls and bbcode problem
2. The quick reply box works fine when I disable my JoomSEO plugin.
Last edit: 15 years 10 months ago by vientogris.
15 years 10 months ago #80588 by eriwet2
Thanks for your input, I'm afraid it doesn't help me though, as I wrote above I have the same problem on my test site with no SEO/SEF component installed, regardless of wich template I use and with legacy mode disabled.
Would be really nice if someone from the Kunena team (or other knowledgable people) could find anything else to try, I'm completely lost.
15 years 10 months ago #80607 by xillibit
You have something which load Mootools 1.1 which doesn't work with kunena, kunena needs Mootools 1.2.x :
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/mootools/1.11/mootools-yui-compressed.js"></script>
I don't know what is loading this, but you try to disable all third modules and plugins, re-enable them one by one to see which one need to be removed.
The following user(s) said Thank You: eriwet2
15 years 10 months ago #80628 by sozzled
eriwet2: Did you disable "legacy mode" as we advised you?
15 years 10 months ago #80668 by eriwet2
Yes
This is my setup now...
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 55M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
15 years 10 months ago - 15 years 10 months ago #80669 by sozzled
Thank you. It's nice to get feedback.
Please upgrade from K 1.6.0 to K 1.6.2. I think that will help with your problems. :)
Also, you might find it worthwhile to upgrade the Kunena Latest module, too.
Last edit: 15 years 10 months ago by sozzled.
