Question How do I enable quick reply?
xillibit wrote: Hello,
You have something which load Mootools 1.1 which doesn't work with kunena, kunena needs Mootools 1.2.x :
Code:<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/mootools/1.11/mootools-yui-compressed.js"></script>
I don't know what is loading this, but you try to disable all third modules and plugins, re-enable them one by one to see which one need to be removed.
I'll try this approach as well, thanks for the tip.
sozzled wrote: Thank you. It's nice to get feedback.
Please upgrade from K 1.6.0 to K 1.6.2. I think that will help with your problems.
Also, you might find it worthwhile to upgrade the Kunena Latest module, too.
OK, I'll try that - now I have lots of things to try, thanks guys!
I realize its a good idea to upgrade to 1.6.2 on my main site as well. But I found that the included Swedish translation needs a lot of work. I can give it a try but I don't know what I need to do to share the results with others.
First I installet 1.6.2 on my test site. That didn't help, then I disabled alla plugins and modules as suggested. This resolved the problem and when enabling the plugins one by one I found that "System - Google Ajax library" was causing this.
Then I tried to disable this plugin on my main site but it didn't help. I then figured that it was the combination of Kunena 1.6.2 and disabling the plugin that was the key. But upgrading to 1.6.2 wasn't enough. I had to look for more conflicting plugins and found that "System - myApiConnect" also needed to be disabled.
Thanks for all help
- vientogris
I thought I solve my problem before but I'm now with the same problem.
Now I can't see the bbcode here, in your kunena forum!! I'm going crazy. I have enter in this support forum with firefox and ie and I can't see it.
Maybe there is a problem with my eyes :pinch:
Well, I have updated my forum two weeks ago and my users don't report me any problem.
In a local copy on my computer now is working fine, I don't understand nothing.
<script type="text/javascript" src="/includes/js/joomla.javascript.js"></script>
<script type="text/javascript" src="/plugins/system/mtupgrade/mootools.js"></script>
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...ed/js/mediaboxAdv.js "></script>
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...lt/js/default-min.js "></script>
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...s/kunena.poll-min.js "></script>
<script type="text/javascript" src=" www.elmultiverso.com/components/com_kune...ult/js/editor-min.js "></script>
<script type="text/javascript" src="/media/system/js/validate.js"></script>
<script type="text/javascript">
- vientogris
:S
This is really strange
Edit: There's something wrong with my computer, my firefox or something. I'm in another computer and I see the bbcodes in my forum, your forum... why?
