Kunena 7.0.8 Released
Question [Merged topic] When the number of views or replies is greater than 9999 ...
- ComposerRyan
- Junior Member
- Thank you received: 3
Each time you upgrade Kunena you will have to remember to change this file.
- ComposerRyan
- Junior Member
open components/com_kunena/class.kunena.php
1) Next find this code:
} elseif ($number >= 1000000) {
$output = $number / 1000000 . JText::_('COM_KUNENA_MILLION');
} else {
$output = $number / 1000 . JText::_('COM_KUNENA_THOUSAND');
2) Next, replace it with this:
$output = $number;
} else {
$output = $number;
I have a very big and busy forum so a lot of topics are viewed more than thousands and thousands of times.
When you look at a category index of the forum you can see that in the column 10.000 views for instance.
I do find the way the views are presented a bit strange. If you look at the file attached in the column 'bekeken' (=views in Dutch). Look at the first topic, it is viewed 61.37duizend (duizend=the word thousand in dutch).
I find that a bit strange. I'd rather have it displayed just in numbers like 61.372 (and not with the word 'duizend').
I have looked in the admin but can't find anything... Is this changeble? And if yes, how can I change it so the views will be like 61.178 / 10.890 again?
Hope someone can help
Kind regards, GertJan
