Question [Merged topic] When the number of views or replies is greater than 9999 ...
15 years 8 months ago #82653 by gjhvs
A little bump... can someone help me with this?
15 years 8 months ago #82655 by 810
Hi gert-jan,
do you have a link to your site.
thnx
15 years 8 months ago #82656 by gjhvs
Here is the link to the forum: www.madonna.nl/site/forum.html
15 years 8 months ago #82659 by 810
i think its a gavick template problem, first can you try to use the kunena default template. if its works, then your own template isn't working perfect, But i also see that he always load the ie7 template. there is the proplem.
regards 810
15 years 8 months ago #82660 by gjhvs
810 wrote: i think its a gavick template problem, first can you try to use the kunena default template. if its works, then your own template isn't working perfect, But i also see that he always load the ie7 template. there is the proplem.
regards 810
I have already tried that, use the standard Kunena template. Also tried to standard Joomla template.
But still the same problem with view counter....
15 years 8 months ago #82662 by 810
can you create me a super administrator account, then i will find it for you. and send it to me by pm
regards 810
Time to create page: 0.296 seconds
