Question Few bugs I have come across as well as anoyances
16 years 1 month ago - 16 years 1 month ago #64752 by weise
Hello all,
Firstly Iam impressed with the forums style/features (Welldone)
I will start with some issues I have found that are annoying me.
logging in seems to have a few problems , users sometimes have to login twice before they are logged in.
I have tested this extensively and cannot quite see why this happening.
secondly when logged in as std user (admin user not effected) I notice this issue;
which is caused in the lattest forums section module published to the (left) column
I use the latest 1.6 version with community builder
config below;
next formatting / annoying links and other odd things that are not easily fixed;
The (code)etc(/code)
template specific changes make this look hidious...
tags ... have this lite yellow BG with Light Grey Text .... I can not find where to change this hidious combination to my own custom colour settings...possibly through configuration panel?
The (spoiler)etc(/spoiler)
tags ... I would like to Change the text to something else but am not able to do so .
the (hide)etc(/hide) feature
Part of the message is hidden for the guests. Please log in or register to see it.
I thought as a addon in the future you could set this up like other type systems where users need to either reply or click on the 'thank you' button to reveal the <hidden> text , also wondering about a hidden moderator type text feature perhaps.
Emoticons: this feature I love and also hate. I like the fact that you can upload smilies and assign them to words like 'omg' and 'a rose' and assign custom smiles to them , as well as being able to not-publish them to the Emo toolbar inside the editor :)
however it is cumbersome and annoyingly slow process to implement. could I suggest that you add a few columns to it with check box's 'tick'/'cross' to enable disable and publish these icon's in the future release?
Finally Branding:
I know how important it is to brand your software but having 10,000 links to this forum is really asking for trouble in a 'forum' situation.
all forums attract the wrong people who have insight into things like , hacking Exploiting and Injecting various attacks to gain access to sensitive data. Personally I remove all Branding so that they do not know what Iam using as this blocks the lamer uneducated hacker types from sploiting the forum . As well as removing Version Specific data from the board so that they can't type into google ;
exploit kunena 1.6 forums
and find a way in through there.
Iam having trouble however removing the email link back to these forums which I also find to be a security risk and notice that you have made it difficult to find all the little links to here...
that is my no.1 priority atm . I know that branding is important but Obfuscation is even more important in this game ..
my 20cents thanks.
just found another problem ,
theres is no delete button to remove attachments; however unticking and submitting seems to be a temp work around for this.
please note that this is a ruff writeup and I inntend to revise it at a later stage.. for the time being Iam trying to find fixes for all of the above problems.
Last edit: 16 years 1 month ago by weise.
16 years 1 month ago - 16 years 1 month ago #64754 by sozzled
Thank you. Unfortunately your long list of questions will require a fair stretch of time to properly answer. For my part, I would like to deal with them gradually over time - the next few days. In the meantime, I would also invite other users to answer those questions that they feel they can handle. This is such a long and involved topic that it could take several weeks before it is completely dispensed with. This is also one of the main reasons why we encourage users to post a single question per topic.
Because I am not sure which issues are defects (or bugs) and what are issues where something is broken or where some features are, as you described them, mere annoyances, I have decided to move this topic to the Common Questions category.
One very quick matter that I would like to address now is the first question you asked, about login.
Kunena is not responsible for user registration, login or logout. These are Joomla features; these are features that may (or may not) be assisted by additional components that you may have chosen to install and integrate with Kunena; these may be features that are incorporated into components like JomSocial or Community Builder. It is possible that the problems you have may be caused or exacerbated by such other components - components that you have not mentioned in your account. It would be good to know what other components you have installed that may interfere or impact on this user login issue that you described.
We also encourage users to provide a copy of their configuration report. Giving us your configuration report saves you time and saves us the time asking you for it. Please remember this in future when you post messages in the Support category. Thank you. B)
Last, but not least, welcome to Kunena! :)
Last edit: 16 years 1 month ago by sozzled.
The following user(s) said Thank You: weise
16 years 1 month ago - 16 years 1 month ago #64755 by weise
hi there , thanks for the sugestions :).
where does one find this report mentioned. also yes I think the login part is just a misconfiguration of probably the CB component.
after using these boards Iam wondering if the cb plugin is still needed?.. as you seem to have covered all / most of what it contains in these excellent forums.
Just a off-topic question.
Where are the modules for the about-me/friends & Groups that you have in your profile?.. are these separate components for Kunena or are they from joomsocial/cb?
thanks
16 years 1 month ago - 16 years 1 month ago #64765 by sozzled
Ah yes, well I can see that this one discussion topic could possibly cover several different categories.
weise wrote:
where does one find this [K 1.6 configuration] report?
The details are provided in one of the sticky posts in the Support category - looking at sticky posts is something you will need to develop the habit of doing. You will find more expansive instructions here: K 1.6 Configuration Report .
There's some help here for users of Community Builder but we're not the CB support forum. If the questions you have are not answered by browsing/searching through the Community Builder category , you should address your questions to our good friends at Joomlapolis .
Community Builder is, strictly-speaking, a Joomla component; the CB component has a number of optional modules, plugins and add-ons that you may or may not find useful. Again, these are a matter of personal choice whether you decide to use or not use any or many of them.
weise wrote:
Just a off-topic question: Where are the modules for the about-me/friends & Groups that you have in your profile?
:laugh: I'm still trying to find what is the topic here! However, your question is a commonly-asked one and is answered by this sticky topic: [Merged topic] Kunena Web Site: What components and modules are used at www.kunena.com ?
16 years 4 weeks ago #65752 by weise
Sorry about this sozzled , but your avatar is really annoying :S
After seeing it some 400 times I can't get the ugly thing out of my head (nightmares even) :laugh:
Just thought I'd let ya know.
16 years 4 weeks ago #65755 by fxstein
weise wrote: Sorry about this sozzled , but your avatar is really annoying :S
Hahahaha... that is too funny. That Iron must be inside my forehead by now... ;-)
Time to create page: 0.147 seconds
