Question [Merged topic] The great CAPTCHA problem discussion
15 years 9 months ago - 15 years 9 months ago #85853 by solinko
Replied by solinko on topic Problem witch captcha
Kunena 1.6 is perfect, but now I have big problem with spam. I installed and set captcha plugin from this site . But I have problem with text in picture. I always see JOOMLACAPTCHA. I can't use this captcha, because nobody can't add new topic or post.
Can me writte somebody where is problem? Thanks very much.
Last edit: 15 years 9 months ago by solinko.
The topic has been locked.
15 years 9 months ago #87307 by blackwinds
Replied by blackwinds on topic reCaptcha for Kunena 1.6
I just created a free reCaptcha plugin for Joomla 1.5
It is very easy to integrate it with Kunena 1.6
You can use it to replace the JCaptcha which can not protect you at all.
The plugin could be downloaded from
blackwinds.popuzone.com/index.php?option...atid=1&cid=6&lang=en
Enjoy!
The following user(s) said Thank You: ender, didie
15 years 8 months ago #87954 by blackwinds
I have upgraded my reCAPTCHA plugin to V1.1 . Now it supports JComments also. I also put the integration file for Kunena and JComments inside the package. You can try if you like.
15 years 8 months ago #88461 by joecort64
To deal with the users that got accounts before you started screening, you should be able to figure out which ones are making the spam posts and remove them from the list of users or just ban them from making posts.
15 years 8 months ago #88575 by didie
Thanks Blackwind, just what I need! ok, I'll check it out, hopefully I'll facing no problem at all. (but if there is any, you'll help right? :) )
15 years 8 months ago #88744 by blackwinds
didie wrote: Thanks Blackwind, just what I need! ok, I'll check it out, hopefully I'll facing no problem at all. (but if there is any, you'll help right? :) )
You are welcome. See if you have any problems I can help.
