Question [Merged topic] The great CAPTCHA problem discussion
16 years 4 days ago #67769 by Troneas
ya by legacy i meant the simple version of it - i thought it might come with the joomla package cant remember. not the google recaptcha that you need a code for.
but if you say all captchas will work then thats good for me. thnx.
The topic has been locked.
15 years 11 months ago #71475 by Zembrzyce
Replied by Zembrzyce on topic Captcha plugin
Which Captcha plugin should I use for Kunena 1.6 RC 2? In 1.5.9 It works without any. Now there is note that I've got no plugin or it's bad configure.
15 years 11 months ago - 15 years 11 months ago #71509 by xillibit
Replied by xillibit on topic Re: Captcha plugin
I advise you to upgrade to k1.6.1 or k1.5.13
to make working captcha in k1.6.0 : docs.kunena.org/index.php/How_to_proper_...aptcha_in_kunena_1.6
Last edit: 15 years 11 months ago by sozzled.
15 years 10 months ago #75557 by flatmattj
Hello
This was the closest topic I could find to post this in. I would like to use a captcha in my setup but only for anonymous posts.
To clarify, my forum is registered users only -no guest posts. I do have a few categories that I turned on Anonymous for due to sensitive information. Is there a way for captcha to only appear when somebody clicks the anonymous button? I can't think of any other way to do this without turning on guest access, which I don't want to do.
Also, does anybody have a recommendation for a captcha with 1.6 if this is possible?
Thanks!
15 years 10 months ago - 15 years 10 months ago #75567 by sozzled
flatmattj wrote: To clarify, my forum is registered users only -no guest posts.!
Then no CAPTCHA
flatmattj wrote: I do have a few categories that I turned on Anonymous for due to sensitive information. Is there a way for captcha to only appear when somebody clicks the anonymous button?
Why do you want this? You've already required that your users have to be logged-in; you've already put your users to the test of verifying their credentials in order for them to use your forum. Why do you feel it necessary to add this additional hurdle? If you allow anonymous then you allow anonymous.
What real problems are you hoping to overcome by trying to implement CAPTCHA in the way that you have requested?
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago #77845 by crazydiver
Replied by crazydiver on topic captcha for kunena?
I would like to know if there is a recommended captcha extension than can be used with kunena please. Or does kunena have its own???
As of now, I am using JoomlaXi Captcha 2.0, it's a really awesome extension but the only problem I have with it when used with kunena is that every time I try to attach a file (jpg,pdf, png, and etc) the file does not attach and responds with this message in my post...
Attachment whaever123.jpg not found
When turning off captcha, it works fine but I would like to have some sort of anti-apam measure. (I had some pretty bad spam attacks in the past.)
I tried turning on the (Enable captcha system with third party plugin) in the kunena backend but still no go.
Any suggestions?
Happy holidays!
The following user(s) said Thank You: markxcool
Time to create page: 0.152 seconds
