Merged [Merged topic] An invalid post ID was requested
After you have enabled debug (either in Kunena or Joomla), you should see Joomla error page. Just copy its contents to this thread.
Call stack
# Function Location
1 JSite->dispatch() Z:\home\myjob\www\index.php:68
2 JComponentHelper->renderComponent() Z:\home\myjob\www\includes\application.php:124
3 require_once() Z:\home\myjob\www\libraries\joomla\application\component\helper.php:162
4 KunenaApp->__construct() Z:\home\myjob\www\components\com_kunena\kunena.php:698
5 CKunenaView->display() Z:\home\myjob\www\components\com_kunena\kunena.php:418
6 CKunenaView->getView() Z:\home\myjob\www\components\com_kunena\funcs\view.php:683
7 JDatabaseMySQL->loadObject() Z:\home\myjob\www\components\com_kunena\funcs\view.php:340
8 JDatabaseMySQL->query() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:435
9 JError->raiseError() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:231
10 JError->raise() Z:\home\myjob\www\libraries\joomla\error\error.php:171
11 JException->__construct() Z:\home\myjob\www\libraries\joomla\error\error.php:136
JDatabaseMySQL::query: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND s.client_id = 0 GROUP BY s.userid' at line 1 SQL=SELECT s.userid, MAX(s.time) AS time FROM jos_session AS s WHERE s.userid IN (64,63,277,393,1041,1087,) AND s.client_id = 0 GROUP BY s.userid
Call stack
# Function Location
6 CKunenaTools->loadTemplate() Z:\home\myjob\www\components\com_kunena\funcs\view.php:693
7 require() Z:\home\myjob\www\components\com_kunena\class.kunena.php:917
8 CKunenaView->displayMessage() Z:\home\myjob\www\components\com_kunena\template\default\view\view.php:49
9 CKunenaViewMessage->display() Z:\home\myjob\www\components\com_kunena\funcs\view.php:634
10 CKunenaTools->loadTemplate() Z:\home\myjob\www\components\com_kunena\funcs\view.php:264
11 require() Z:\home\myjob\www\components\com_kunena\class.kunena.php:917
12 CKunenaViewMessage->displayProfile() Z:\home\myjob\www\components\com_kunena\template\default\view\message.php:92
13 CKunenaTools->loadTemplate() Z:\home\myjob\www\components\com_kunena\funcs\view.php:93
14 require() Z:\home\myjob\www\components\com_kunena\class.kunena.php:917
15 KunenaUser->isOnline() Z:\home\myjob\www\components\com_kunena\template\default\view\message.profilebox.php:56
16 JDatabaseMySQL->loadObjectList() Z:\home\myjob\www\administrator\components\com_kunena\libraries\user.php:264
17 JDatabaseMySQL->query() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:458
18 JError->raiseError() Z:\home\myjob\www\libraries\joomla\database\database\mysql.php:231
19 JError->raise() Z:\home\myjob\www\libraries\joomla\error\error.php:171
20 JException->__construct() Z:\home\myjob\www\libraries\joomla\error\error.php:136
Do you migrate from k1.5 with hack poll ?
Maybe it`s no correct, i don`t check other code
I migrate without hack poll.
UPD
I update 1.5.3 to 1.5.12 and migrate to 1.6
