Solved Joomla user group not updating in Kunena - Help please
14 years 4 months ago #126790 by oceanborn82
Never mind.. just found out Joomla 2.5 does not use the usertype feature anymore. Hence the blank areas.
The member I upgraded to author who told me he could not see secret forum categories was having a blonde day and they were there all along.
Sorry for wasting peoples time
14 years 4 months ago - 14 years 4 months ago #126791 by sozzled
K 1.7.2 does not detect the more "advanced" Joomla user types (i.e those you may set up in J! 2.5.x, for example) when producing the user list.
My suggestion is to remove the user type from the list. Use the configuration setting:
Forum configuration » Plug-ins » Userlist » Show User Type = No
Simple, easy, clean, effective. ;)
Last edit: 14 years 4 months ago by sozzled.
14 years 4 months ago #128808 by fahima
sozzled wrote: K 1.7.2 does not detect the more "advanced" Joomla user types (i.e those you may set up in J! 2.5.x, for example) when producing the user list.
I already tried that configuration, but problem still exists :(
Do you have any other suggestions?
14 years 4 months ago #128840 by Matias
Issue is probably in your template. Try if changing to default template helps. If it does, you need to contact the author of the template to fix the issue.
