Solved How to make signature optional
14 years 5 months ago #125528 by sozzled
I think your problem is caused by a Javascript library function. This could have been introduced when you installed jQuery or the K2 component.
I suggest that you read msg #1 of Common causes of Mootools (Javascript library) issues and Kunena in the Wiki and consider loading jQuery in no-conflict mode; you might also have to re-order your plugins so that Mootools is loaded before any other plugins.
The following user(s) said Thank You: extrannonces
14 years 5 months ago - 14 years 5 months ago #125540 by extrannonces
thank you very much for your help, I found the problem, when I did a test with another site template, everything works as it should.
thank you
Last edit: 14 years 5 months ago by extrannonces.
