Solved How to make signature optional
14 years 5 months ago #125504 by extrannonces
when I edit my profile, signature is required, how to make it optional.
thank you
14 years 5 months ago #125513 by sozzled
I have never heard of this happening before. :unsure: Can you please post your K 1.7 configuration report?
14 years 5 months ago - 14 years 5 months ago #125521 by extrannonces
I use version 1.7.2
the forum url www.compta-maroc.com/forum/index.html
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : shaper_helix | author: JoomShaper.com | version: 1.5.0 | creationdate: Jan 2011
Modules: Kunena Latest 1.7.2 | Kunena Login 1.7.2 | Kunena Search 1.7.2
Last edit: 14 years 5 months ago by extrannonces.
14 years 5 months ago #125524 by sozzled
Thank you for your config. report. I could not see anything obvious in that report that suggests to me why the signature field is required before you can save the profile.
I was able to remove the signature from my profile here (although we're using a different version of Kunena to you) and I restored it again.
Perhaps there's some Javascript library function that you've added (with another Joomla extension) that forces you to enter a non-null signature?
Do you have a test account that we can use? You can post it here, on the forum, using the confidential BBcode tag, like this:
[confidential]Username: Password:[confidential]
Maybe we can try to edit the test account forum profile to add, then remove, the signature?
14 years 5 months ago #125525 by extrannonces
You can use this one:
14 years 5 months ago #125526 by sozzled
I will have a look soon. :)
