- Thank you received: 1
Solved Direct accessing the kunena component and permissions.
Sometimes
Warning: Using direct link to Kunena component. Redirected to menu item in /forum (ItemID=149).
Please check your Joomla menus: Infinite redirect loop detected in /forum
Kunena Menu is missing: You cannot have menu in direct links pointing to Kunena component. You need to create menu item matching to this page.
Sometimes it works
And sometimes the page remains blank and I get this php notice
Notice: ob_end_clean() [ref.outcontrol]: failed to delete buffer. No buffer to delete. in /var/www/vhosts/***mydomain***.com/httpdocs/plugins/system/debug/debug.php on line 79
Kunena menu details:Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
| 150 | Index | index | kunenamenu | index.php?option=com_kunena&view=listcat | forum/index |
| 151 | Recent Topics | recent | kunenamenu | index.php?option=com_kunena&view=latest | forum/recent |
| 152 | New Topic | newtopic | kunenamenu | index.php?option=com_kunena&view=post&do=new | forum/newtopic |
| 153 | No Replies | noreplies | kunenamenu | index.php?option=com_kunena&view=latest&do=noreplies | forum/noreplies |
| 154 | My Topics | mylatest | kunenamenu | index.php?option=com_kunena&view=latest&do=mylatest | forum/mylatest |
| 155 | Profile | profile | kunenamenu | index.php?option=com_kunena&view=profile | forum/profile |
| 156 | Rules | rules | kunenamenu | index.php?option=com_kunena&view=rules | forum/rules |
| 157 | Help | help | kunenamenu | index.php?option=com_kunena&view=help | forum/help |
| 158 | Search | search | kunenamenu | index.php?option=com_kunena&view=search | forum/search |
Joomla default template details : android-area | author: Biowep | version: 1.0 | creationdate: 10 February 2012
Like sozzled said, you should delete all menu items (in every menu) that are pointing to Kunena and empty trash (deleting isn't enough). After that recreate menu from Kunena backend. Then go into default menu (marked with star) and publish "Forum".
I hope that my advice was easier to understand than the previous one.
I trashed all the elements in the kunena menu.
I emptied the trash.
I removed the kunena menu.
I removed the forum pointer in the main menu (the one marked with the star).
I emptied the trash again.
I uninstalled Kunena by trying to install it from the archive.
I deleted the content of the tmp folder.
I deleted the whole cache.
I refreshed the extensions installation page.
I installed Kunena again (from the archive).
I checked the menu items in the Kunena menu (all menu items are published)
I published the pointer to forum in the main menu.
If I continue to nativate through the menus and ask for "site/?option=com_kunena", Sometimes I get one of those 2 errors (I don't know exactly how to reproduce the error, it seems to be casual).
Looks like you've done everything what I would have done. Is your site live or just a test site? Because of my next suggestion is to try Kunena 2.0 (in a test site) as it does routing in a very different way & it has some basic tools to check if there are any issues in your menus.
Your configuration report tells me that you're not using 3rd party SEF component. As we do not detect all of them, I would like to ask if it's true?
Ok, I will try kunena 2.0 (it's just a test site). If I find any error, I'll let you know.
Thank you both for your support.
It's impossible for me to reproduce these errors on your site, too. Your forum only has the original sample data posted (there are no other messages), as far as I can tell, and all the menus function properly for me.biowep wrote: Sometimes I get one of those 2 errors (I don't know exactly how to reproduce the error, it seems to be casual).
But ... your configuration report does not show any details of forum configuration settings and that's why I'm wondering what's going on! :dry: Seems to me that the installation procedure did not properly construct the xxx_kunena_config table in the database.
The configuration report clearly shows that this still looks like a faulty/incomplete installation to me.
