Solved Direct accessing the kunena component and permissions.
14 years 5 months ago - 14 years 5 months ago #125048 by biowep
Hi, If I try to directly access the forum (?option=com_kunena) I can see the index page although the user would't have been allowed to see it through the menu item (/forum). Is it a mistake?
Last edit: 14 years 5 months ago by sozzled. Reason: Change topic icon
14 years 5 months ago #125049 by sozzled
No it's not a mistake. You need to setup Joomla SEO to use SEF (search engine friendly) URLs. See Search Engine Optimisation (SEO)
14 years 5 months ago - 14 years 5 months ago #125056 by biowep
Maybe I didn't explained properly. I have Joomla SEF URLs active and the user can access the page through the menu item (/forum).
The menu have an access option.
I tried to access the page "/forum" using an user that doesn't have got the right permissions. (I'm redirected to the login page)
If that user tries to view the forum, asking for "?option=com_kunena" he can view it.
The sistem is aware that the component was accessed directly because it shows an error message:
Warning: Using direct link to Kunena component. No suitable menu item found.
Kunena Menu is missing: You cannot have menu in direct links pointing to Kunena component. You need to create menu item matching to this page.
Last edit: 14 years 5 months ago by biowep.
14 years 5 months ago - 14 years 5 months ago #125059 by sozzled
If you search the forum for "Warning: Using direct link to Kunena component. No suitable menu item found." or if you search the forum for "Kunena Menu is missing: You cannot have menu in direct links pointing to Kunena component. You need to create menu item matching to this page. " you will find many posts that show you what you need to do. I am willing to bet you any money you like, you have not properly set up Joomla SEO including setting up your Kunena menu. Your configuration report may help us to understand more about your situation.
14 years 5 months ago #125147 by biowep
I followed the documentation but I didn't solve.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : android-area | author: Biowep | version: 1.0 | creationdate: 10 February 2012
Any help will be appreciated.
14 years 5 months ago #125160 by sozzled
Your Kunena was not properly installed. Uninistall Kunena, trash (and empty the trash) all Kunena menu items in Joomla Menu Manager, and then re-install Kunena again. Publish your new Kunena menu again after that.
The following user(s) said Thank You: biowep
