Solved [Resolved] Guests cannot able to view the categories/posts without login
14 years 7 months ago #123375 by sozzled
Thanks for the bit of information that you posted but I suggest you read the posting guide printed at the top of this page and, in particular, What information should I include when I ask for help (including how to post my configuration report)?
14 years 7 months ago - 14 years 7 months ago #123376 by antony
Hi Sozzled,
Sorry and Please find my config,
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 2.5.0 | creationdate: February 2012
Last edit: 14 years 7 months ago by sozzled. Reason: Reveal K 1.7 configuration report in message
14 years 7 months ago - 14 years 7 months ago #123381 by Jiminimonka
[strike]Please paste your configuration report into your reply. The Confidential tags hide all the important stuff from non-moderators, and it is also formatted for the Kunena forums so its easier to read. A .txt file makes it hard to read.[/strike]
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 7 months ago by sozzled. Reason: no longer necessary
14 years 7 months ago - 14 years 6 months ago #123397 by sozzled
antony: Thanks for you configuration report. Unfortunately there is not a lot that we can do to directly help you in this case because your website is not accessible on the internet. Please read xamp .
I suggest that you read When all else fails, try this
Good luck in trying to resolve the problems that you are having.
14 years 6 months ago #123693 by antony
Thanks... I have Solved the issue. Modified public access 0 to 1 in menu table in my db.
