Bug Users cannot see all forum categories while they are granted to
14 years 1 month ago #123011 by sebnunes
The Session is 30min.
No the topics are not visible overnight. Even days after, it's still not visible for them...
14 years 1 month ago #123018 by sozzled
See Problem with Kunena Session for information about session settings.
Can we see your K 1.7 configuration report again, please? I would like to check a couple of things. Thanks.
14 years 1 month ago #123033 by sebnunes
OK, thanks I'll check the session information.
here is the configuration:
Legacy mode: Enabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 384M | Max file upload: 100M
Joomla default template details : dsb2011 | author: Sébastien Nunes | version: 1.0.0 | creationdate: 31/12/2010
Kunena default template details : Aphotic II | author: snilloconator | version: 1.6.2 | creationdate: 2010-12-30
Third-party components: UddeIm 2.1
14 years 1 month ago #123056 by sozzled
We advised you before to disable legacy mode and not to use a third party-developed template that is unproven and untested with K 1.7.2.
We also advised you to delete your existing Joomla menu items that refer to Kunena and to restore the Kunena menu.
We gave you this advice in our first reply to you.
You have chosen to ignore that advice. I'm sorry, there is nothing more that we can do to help you.
The following user(s) said Thank You: sebnunes
14 years 1 month ago #123105 by sebnunes
Hi, Thanks for your answer.
I didn't wanted to ignore your advices but the problem is occuring on my production site, I cannot rollback to the default template while having users coming every day on the site.
I'll duplicate the site to investigate on a copy version.
I was hoping to find a solution directly on the production site.
Thanks for your help and your advices.
14 years 1 month ago #123159 by sozzled
sebnunes wrote: I was hoping to find a solution directly on the production site.
You want a solution for your production site but you're not willing to accept the solution that we have proposed. Again, we're sorry if this is an unpopular choice for you but the facts remain:
(1) Legacy mode causes problems;
(2) Unsupported and out-of-date software (including third-party templates for Kunena) cause problems;
(3) Non-standard implementations of Joomla menus cause problems.
Time to create page: 0.292 seconds
