Question [Resolved] Problem with installation kunena 1.7.2
14 years 9 months ago #117590 by 810
go to your database.
delete all jos_community_*
regards 810
14 years 9 months ago #117652 by vehuel
There are not jos_community tables in my db
14 years 9 months ago #117655 by Jiminimonka
The error you printed is something to do with Jomsocial, read the error again.
That is what is causing your problem. So either you have Jomsocial installed somewhere and don't know about it, or you have partly un-installed it manually and it is looking for a database entry that does not exist.
Add your configuration report to your next post and don't edit it so the support team can look into it properly.
Please read the FAQ.
Only one question per topic.
14 years 9 months ago #117656 by Jiminimonka
Also READ
sozzled wrote: The errors (mentioning jos_community_users) refer to JomSocial. If you are getting these messages it means you have set something on your site referencing JomSocial. Try resetting your Kunena configuration to the original default values.
14 years 9 months ago #117657 by vehuel
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 64M
Joomla default template details : gk_finance_business | author: Robert Gavick - GavickPro | version: 1.0.5 | creationdate: 31/10/2011
Third-party components: Jomsocial 2.0.6
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
14 years 9 months ago #117658 by Jiminimonka
vehuel wrote: Third-party components: Jomsocial 2.0.6
Don't have Jomsocial installed?
