Question [Resolved] Problem with installation kunena 1.7.2
14 years 9 months ago - 14 years 9 months ago #117556 by vehuel
I have joomla 1.5.25 and when i install kunena 1.7.2 in the front end i receive the following error:
DB function failed with error number 1146
Table jos_community_users' doesn't exist SQL=INSERT INTO `jos_community_users` ( `userid`,`points`,`thumb`,`avatar`,`params` ) VALUES ( '62','0','','','notifyEmailSystem=1\nprivacyProfileView=0\nprivacyPhotoView=0\nprivacyFriendsView=0\nprivacyVideoView=1\nnotifyEmailMessage=1\nnotifyEmailApps=1\nnotifyWallComment=0\n' <h2>DB function failed with error number 1146
Last edit: 14 years 9 months ago by vehuel.
14 years 9 months ago #117558 by 810
Please update Jomsocial first,
regards 810
14 years 9 months ago - 14 years 9 months ago #117582 by vehuel
Jomsocial?
I have not installed jomsocial, i need only kunena forum
have i to download another pack?
thanks
14 years 9 months ago - 14 years 9 months ago #117583 by sozzled
The errors (mentioning jos_community_users) refer to JomSocial. If you are getting these messages it means you have set something on your site referencing JomSocial. Try resetting your Kunena configuration to the original default values.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago #117586 by vehuel
It's a mistery. I have not installed jomsocial.
I have only installed kunena
What can i do?
regards
14 years 9 months ago #117587 by vehuel
the url is:
index.php?option=com_kunena&view=entrypage&func=entrypage&Itemid=247
