Question K 1.6.3: Post message success but not loading current thread
14 years 10 months ago - 14 years 10 months ago #116715 by hellilyntax
hi,
sorry for blurry title. i don't know how to make it clear in one sentence. :P
fyi,
im using j1.5.3 and kunena 1.6.3
im having this issue on certain thread. After post a message on a thread, it didn't load the thread but stuck at this screen:
[img]http://http://www.al-fikrah.net/media/kunena/attachments/63/redirect_error.jpg[/img]
after doing some investigation, i assume that the page stuck at kunena menu (without styles) but failed to show thread content.
it happen to certain thread. i cannot identify the polarity. some are long (many pages), some are short (5 replies).
Last edit: 14 years 10 months ago by hellilyntax.
The topic has been locked.
14 years 10 months ago #116720 by hellilyntax
after further investigation, i found that there is difference between success load and failed load.
here is the sample,
success load = mysite/index.php?option=com_kunena&func=view&catid=32&id=2937&Itemid=139#3329
failed load = mysite/index.php?option=com_kunena&func=post&Itemid=139
now i need to know how this happen in order to solve this issue...
14 years 10 months ago - 14 years 10 months ago #116736 by sozzled
Have you tried upgrading to K 1.7.1 to see if the upgrade solves your problems? See K 1.6 and K 1.7 Upgrade Guide
Last edit: 14 years 10 months ago by sozzled.
14 years 10 months ago #116761 by hellilyntax
sozzled wrote: Have you tried upgrading to K 1.7.1 to see if the upgrade solves your problems? See K 1.6 and K 1.7 Upgrade Guide
i have successfully upgraded to 1.7 before but some problems occur after upgrade.
so i revert back to 1.6 by replacing the whole site.
i would be glad to have 1.7 on my site again. is there any simple way to upgrade and revert back in case there is a problem? replacing the whole site is not recommended.
14 years 10 months ago #116763 by sozzled
What problems did you have after you went to K 1.7.1? Would it not be a better idea to work through those problems?
The following user(s) said Thank You: hellilyntax
14 years 10 months ago #116772 by hellilyntax
sozzled wrote: What problems did you have after you went to K 1.7.1? Would it not be a better idea to work through those problems?
thanks for your concern.
the problem is, when i click reply button, the page didn't load the editor (textbox). there's maybe already solutions on this issue, but i don't want to interrupt my forum, so i decided to continue with 1.6.
if there is a way to rollback update, then i would try it again.
