Question Emoticon Problems
14 years 9 months ago #116800 by Dreeg
Replied by Dreeg on topic Re: Emoticon Problems
Yes, you have already described the removal of "More Emoticons". :( :(
With regard to the Kunena menu I chose to remove it to recreate it in the left bar :P
I'll wait K1.7.2 ;)
Thank You :cheer:
The topic has been locked.
14 years 9 months ago - 14 years 9 months ago #116803 by sozzled
Replied by sozzled on topic Re: Emoticon Problems
Dreeg wrote: With regard to the Kunena menu I chose to remove it to recreate it in the left bar
Yes you did ... and you didn't. You actually made a bit of a mess of it. I suggest you read Customised menus
I still don't defintely know what has caused the problems you've got with your emoticons . I think it's something you have done in the way you went about setting them up in the first place - that is why I think Smiley management should help.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago - 14 years 9 months ago #116808 by Dreeg
I read yesterday that you had directed me, but I can't find anything new. I haven't changed anything about the emoticons, I just added some (meme xD)
Last edit: 14 years 9 months ago by Dreeg.
14 years 9 months ago #117554 by Dreeg
With Kunena 1.7.2 the problem is not solved :(
14 years 9 months ago #117561 by sozzled
I have fixed your emoticons. If you read Smiley management you would see
Although any text can be substituted, it's a good idea to place a colon (:) before and after the text you will be substituting (e.g. :yuck:, :lol:, :dry:)
It appears that it's not just a good idea, it's also very important to make some kind of distinction!
I changed the emoticon codes you were using. Look at the changes I've made.
I would have fixed your menu but I did not have the right level of access. For example, you do not have a forum search feature that I could find.
In future, when you post messages in the Support category, please post your configuration report, like this:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 10M
Joomla default template details : uwp_1_2 | author: Dreeg | version: 1.2 | creationdate: 2012-01-24
14 years 9 months ago - 14 years 9 months ago #117634 by Dreeg
So the forum REQUIRES the ":"?
Sorry for the oversight of the configuration..
Tomorrow I will add a Search module or the voice menu, but not mandatory. Right?
Time to create page: 0.157 seconds
