- Thank you received: 3
Question Call to joomla clean method after a new post is save/old post edited
Is the symptom of the problem that you still see the NEW! indicator even though you have viewed or posted to a topic?
In joomla 1.6+/1.7+ there is no expire time in the page cache plugin, so the cache clean method must be called from any extension after it makes any change, Am I correct?
Using this new page cache plugin in joomla 1.7+ I've expreimented a better (very high difference) performance.
I have kunena in a joomla 1.5.25 website. I've enabled the cache plugin with a very high expired time and the results are very good, I'm really happy. I've just coded a com_content plugin to trigger onAfterContentSave event and clean the cache after a new article is saved or an old one is edited. I've also configure a cron job to purge expired cache files periodically.
I'd like to do something similar with kunena applying the clean cache method after a new post is saved or an old one is edited, is kunena "plugiable" or I have to hack a core file??
As far as the "new" indicator is concerned, there is an issue that arose in J! 1.5.23 that causes a problem. See Problem with Recent Topics Tab; not refreshing .
Thanks anyway.
