Question Is kunena still using jQuery?
15 years 1 week ago #111111 by cybnet
I'm using kunena 1.7.0 and I've noticed that jquery-1.5.2 is loaded in kunena pages from Community Builder. How can I remove this? I really don't need jquery in kunena pages.
15 years 1 week ago #111125 by xillibit
Kunena doesn't need jQuery, you need found which plugin or module of community builder is loading jQuery
15 years 1 week ago - 15 years 1 week ago #111126 by cybnet
Hi!! Thank you for your reply.
Currently I only use CB login module in kunena pages, not other plugin nor module related with CB.
I've looking at CB module php file and I don't find any reference to jquery.
Last edit: 15 years 1 week ago by cybnet.
15 years 1 week ago #111127 by cybnet
I've swithced to default template and still jquery-1.5.2 is loaded. So is not from my template.
Is there any way I can found from where this js is loaded?
15 years 1 week ago #111128 by cybnet
Finally I've found that jquery 1.5.2 is loaded if any of the integration otptions is set to Community Builder, can I disable this?? I only want to show Avatar wiht link to CB profile, jquery is really don't needed.
15 years 1 week ago #111129 by xillibit
Which Kunena and CB versions are-you using ?
