Important Kunena conflicts with all templates rocketheme, help me.
14 years 10 months ago - 14 years 10 months ago #111012 by neon26
This is the report
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : rt_radiance | author: RocketTheme, LLC | version: 1.1 | creationdate: September 8, 2011
Third-party components: CommunityBuilder 1.7 | UddeIm 2.5
Modules: Kunena Latest 1.7.0 | Kunena Login 1.7.0
As for Rockbox Rockgzipper and since I had published and unpublished but everything remains the same.
There is something that is not what you mean.
What do you mean by that?
and turn off Build Title spans in the Rockettheme template parameters.
Thanks sozzled
Last edit: 14 years 10 months ago by sozzled.
14 years 10 months ago #111021 by sozzled
I looked at your website and you still have some CSS code aggregator software running. If it wasn't RokGZipper it must be something else. Please uninstall RockGZipper. We can then look at your site after you've done that.
14 years 10 months ago #111023 by neon26
Well I completely uninstalled and my site Rockgziper remains the same
Thanks ;)
14 years 10 months ago #111027 by sozzled
Look at all the source references to your CSS and Javascript files (here are just a few):
<link rel="stylesheet" href="/components/com_comprofiler/plugin/templates/luna/css-37ba93563d6146bb202f779575e4b5a1.php" type="text/css" /> <link rel="stylesheet" href="/components/com_kunena/template/default/css/css-f2d2624ce3888655ee619da2d91be366.php" type="text/css" /> <link rel="stylesheet" href="/components/com_uddeim/templates/default/css/css-febe3c9989d480981c56cd7a1af4ac4c.php" type="text/css" /> <link rel="stylesheet" href="/plugins/system/rokbox/themes/light/css-b518d664167dd795248190ff44b8159f.php" type="text/css" /> <link rel="stylesheet" href="/libraries/gantry/css/css-0e5042ebc3c9c083fc851dbfb00627ae.php" type="text/css" /> <link rel="stylesheet" href="/templates/rt_radiance/css/css-d3f6bd10f0bd2761df931694c936dd53.php" type="text/css" /> <link rel="stylesheet" href="/modules/mod_rokajaxsearch/css/css-689006618e74f6afb2d6046e279456dc.php" type="text/css" /> <link rel="stylesheet" href="/modules/mod_rokajaxsearch/themes/blue/css-987089880c8de79c045089990e5a4d17.php" type="text/css" /> <script type="text/javascript" src="/cache/js-61b9d54c9e17f192c9cea4aafe2e2327.php"></script>
The odd thing about these filenames are all those hexadecimal numbers followed by .php after them. In other words, you have something installed on your website that is aggregating and obfuscating the CSS and Javascript and I don't know what it is. It's probably something installed by Rockettheme, but it could be something else you've installed. Please ask Rockettheme if they are aware of this problem, after all, you paid for their template and support. ;)
The following user(s) said Thank You: neon26
14 years 10 months ago #111031 by neon26
Ok
The problem is solved
I tell you in case someone comes to the same thing happens.
There is a conflict between the templates and kunena rockttheme but resolved very easily.
You must log in rockttheme template and "advanced" and then turn
Build Titles Spans
And this is already solved,
thank you very much
14 years 10 months ago - 14 years 10 months ago #111135 by Hurr1c4n3
Last edit: 14 years 10 months ago by Hurr1c4n3.
Time to create page: 0.266 seconds
