Important Kunena conflicts with all templates rocketheme, help me.
14 years 10 months ago #110971 by neon26
Hi all,
I want to make clear that I'm Spanish and my English is very poor.
I have a problem, a conflict with my template and kunena rocketheme, I tried several templates rocketheme so I concluded that kunena not work well with these templates.
The problem is this:
Edit profile does not work, I can edit the profile kunena.
Link does not work "who is connected"
Put an ad does not work, I can enter but not edit
I'd like to give me a solution to this problem
thanks
14 years 10 months ago #110972 by sozzled
Edit profile does not work, I can edit the profile kunena. See msg #1 of If you are having problems with Kunea, please read this first
Link does not work "who is connected" Can you show us a picture of what you mean, please?
Put an ad does not work, I can enter but not edit I don't know if this has anything to do with Kunena. Perhaps this Module Positions might help?
14 years 10 months ago #110976 by neon26
I mean these ads kunena
and I can not enter here into "who is online"
14 years 10 months ago - 14 years 10 months ago #110978 by sozzled
Maybe we should see your website (and your forum) to see what you've done (or how your site template seems to have messed up things). Can you give us a URL, please?
Again, I'm not sure why you cannot edit forum announcements (Anuncios, in your case). If you see the link then you should be able to edit the announcement. This, also, might be something caused by your [Rockettheme] site template.
Last edit: 14 years 10 months ago by sozzled.
14 years 10 months ago #110979 by neon26
www.josportal.com/foros this is my forum
The problem is template rocketheme but all templates rocketheme
14 years 10 months ago - 14 years 10 months ago #110980 by sozzled
Something doesn't look right here. Can you possibly post your configuration report , please?
Are you using some kind of CSS aggregator, like RokGZipper? I suggest you disable it. You might also need to disable RokBox and turn off Build Title spans in the Rockettheme template parameters.
