Question Everything works except [IMG] bbcode.
15 years 1 month ago #109573 by Madturnip
Everything on my forum seems to be working, it was a port from SMF 2.0, but when I use the [ IMG ] bbcode the images are never displayed.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 64M
Joomla default template details : maxedmag | author: Shape5.com | version: 1.0 | creationdate: July 2011
15 years 1 month ago #109580 by xillibit
Can-i see it somewhere on your site ?
15 years 1 month ago #109581 by Madturnip
teamrezurrection.com/rank4/index.php?opt...=6&id=360&Itemid=343
there are [ img ] in those posts, but they do not show up. However, they do show if you RSS feed link it.
15 years 1 month ago #109589 by Madturnip
changing templates does not effect the [ IMG ] bbcode display.
It's quite weird because everything else works, that I can tell, 100% with no issues. If I view it as an RSS feed the images show up and if I view it as a PDF the images show up, but not just viewing the forum. Attachments work just fine... Baffled!
15 years 1 month ago #109591 by sozzled
I'm only guessing but I wonder if you have looked at how to insert an image in Kunena show that the image displays inline with the text instead of as an attachment. Do you know how to do that? Have you read [Merged topic] K 1.6 FAQ - How to display an attached image with the message display ?
15 years 1 month ago - 15 years 1 month ago #109592 by Madturnip
That's all well and good going forward, but all my posts with the use of [ img ] are not displaying. I don't even know where to begin to look in code to see if I can fix it.
Also not sure why this got moved from support to common questions. As this is not a common issue or it would have been solved for me already. I have searched the entire forum and have found other issues, but none like mine. Therefore this would be a seeking support thread and not a common question.
Last edit: 15 years 1 month ago by Madturnip. Reason: Not sure why my topic was moved to a non-topic related board.
Time to create page: 0.154 seconds
