Question No announcement box
15 years 1 month ago #108729 by cambler
No announcement box was created by cambler
Latest install of 1.7.1
Looking at the diplayBox() function in kunena.announcement.class.php, I see that the announcement box only shows if the "show announcement" is true in the configuration *AND* there is an ID of a valid announcement.
This makes sense except for one problem: on a new install, there are no announcements, so the box never shows. Since the box never shows, the options to create new announcements is never seen, so an announcement can't be created. Ever.
Bug?
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 512M | Max file upload: 10M
Joomla default template details : rt_momentum | author: RocketTheme, LLC | version: 1.2 | creationdate: October 4, 2011
Modules: Kunena Latest 1.7.0
15 years 1 month ago #108753 by xillibit
Replied by xillibit on topic Re: No announcement box
You should have a link to go to announcements page if you the permission, this should help you : docs.kunena.org/index.php/Kunena_Announcements
15 years 1 month ago #108780 by cambler
Replied by cambler on topic Re: No announcement box
Yes, and what I'm saying is that the check for the ID of the announcement fails to show this display if there are no announcements.
Removing that ID check fixes the problem.
15 years 1 month ago #108786 by xillibit
I need to look this more closer, this is weird
15 years 1 month ago #108788 by cambler
Look at the code in diplayBox() - you will see two checks on the conditional. The first is for announcements being configured as enabled. The second is a check on the ID. It's the second that causes this bug.
15 years 1 month ago #108795 by xillibit
When you have no announcements, you don't need to have this box because you have the announcement link :
Time to create page: 0.150 seconds
