Question Forums "Disappear" When Not Logged In
Are there any Global Config settings that could be the problem? (Default Access Level is set to 'public'.)
Steve
Matias wrote: I don't think that there's a bug -- the code is so simple:
We Just get all the groups where the user belongs into (recursively):
JAccess::getGroupsByUser(JFactory::getUser()->id, true);
.. and then we check if the group you have entered in category configuration matches one of those.
So easiest way to see the groups visitor is to add this code into somewhere where it gets run:It returns list of user group id's (all that user belongs into)..Code:print_r(JAccess::getGroupsByUser(JFactory::getUser()->id, true));die();
I have the same problem described by Griz44
I installed Kunena 1.6.5 on Joomla 1.7. The public cannot view the sections and categories. Only logged-In user can view.
Prior to installation I did make some changes to the Joomla ACL by adding a guest group. However, I do not think it affects the public view right?
I did nothing more than that, and immediately after Kunena installation I can't view the forum. Please assist. Thanks.
Users >> Options >> Guest User Group >> Public
Prior to this the settings:
Users >> Options >> Guest User Group >> Guest
But I need to prevent logged-in users to see certain content which are meant for the guest group.
So, is there anything I can do?
Like I said earlier, this works:
Edit Category > Settings:
Public Access Level: Public
Admin Access Level: Guest
or:
Public Access Level: Guest
Admin Access Level: Public
I think we need to rename "Public" and "Admin" into "Primary" and "Secondary" for Joomla 1.6+..
And I could still use some help with it...any suggestions? Anybody?!? :sick:
