Question How can I display all categories on index page?
14 years 11 months ago #100757 by RayTurner
Fixed 'default page' screw up. Have had caching disabled since I started work on site. Selected 'None' parent category id again. Still no luck.
Thanks for all your help. Some variable is bound to fall in place someday. Glad to try any other ideas you have.
Ray
14 years 11 months ago - 14 years 11 months ago #100758 by sozzled
See image below:
You see, if you click the link on the home page you only get the General Forum category. If you then click the Index tab you will see all the categories. The Index tab contents are defined by the changes you made. The problem lies with the link on your home page. The link should be Menu Type = Alias.
How have you defined this menu item? This, I believe, is the key to solving the problem. Again, see Customised Menus for the answer. Your K 1.6 configuration report will provide the necessary information I seek. Thank you.
Last edit: 14 years 11 months ago by sozzled.
The following user(s) said Thank You: RayTurner
14 years 11 months ago #100798 by RayTurner
Thank you so much. This last bit of guidance did the trick and all works the way I want it now. I've also learned a few things about Kunena (and Joomla) in the process.
Perhaps with a bit more experience I'll be able to pay it forward for someone else with a similar problem.
Thanks again for your patience and detailed help......Ray
