- Thank you received: 1
Question How can I display all categories on index page?
I appreciate any help. Thanks.
Ray
engagecreatelearn.org
If I understand your question, you would like your forum to behave in the same way as it does here at this website. Is that correct? I think this is a FAQ (see the FAQs tab at the top of this page). Maybe this topic will help you: K 1.6 - Change the "default view" of the forum from Recent Topics to Index
Or maybe a big red button labeled Open All Categories here.
I looked through all the FAQs and searched the forum and the wiki with all the terms I thought might find the answer. This must be simple adjustment. Right?
Thanks again for your help....Ray
(1) Go to Menus » Kunena Menus » Category Index » Parameters (Basic) » Parent Category ID
(2) Change the value that you have at the moment - which is "General Forum" - to the first item in the pull-down list (the first item in the pull-down selector looks like "nothing") and save that change.
That's all that you need to do. I'm sorry for my earlier reply. I had mistakenly assumed, incorrectly, that you had changeoriginal menu configuration (and you didn't mention that you had changed it, either). Out-of-the-box, without changes, when Kunena is installed, it works; it's when people make changes that some things may fall apart.
Thank you for your question, Ray. I learned something new that I would not have otherwise known because I rarely change the standard, default arrangement.
You should not have checked the Default Page option. This makes your forum your site default page (i.e. your site home page). Is that what you want?
Yes, in J! 1.6 the Parent Category ID is "None" (not <null> like in J! 1.5). You should see the changes immediately unless you have curiously used some caching options on yoru site. Server caching in a rapidly, dynamically changing web environment like Kunena, may cause unexpected consequences. In most large forum environments, it is probably better to disable server caching completely. I don't know if the situation has improved in J! 1.6 or not but there are all kinds of problems if you enable the System - Cache plugin (certainly in J! 1.5). Does this help?
