Merged [Merged topic] "Remember me" issues
15 years 1 month ago #108240 by PJFonseca
The configs right now are this:
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 100M
Joomla default template details : ja_purity | author: JoomlArt.com | version: 1.2.0pt | creationdate: 12/26/07
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.4 | creationdate: 2011-05-07
Third-party components: UddeIm 2.0
Modules: Kunena Latest 1.0.47
14 years 9 months ago - 14 years 9 months ago #118248 by sv8bur
Hi, the problem that I have at my forum " www.boyshobbies.com " is that even if I check the "Remember me" it continues to ask for password
and a second problem is : my forum is in Greek language and the word "Σελιδα" which means "Page" wherever it appears, does not display the entire word see attachment
Thank you very much
Last edit: 14 years 9 months ago by sv8bur.
14 years 9 months ago #118249 by idlamalif
cek configuration. .
try look my forum. . .
www.Lam-Alif.com
14 years 9 months ago #118250 by sv8bur
thank you for your answer but if can tell me where to check in the configuration, because I checked everything without finding anything
14 years 9 months ago #118302 by sozzled
G'day, sv8bur, and welcome to Kunena.
I remember that I've seen other questions asked about this problem before, and I thought that this problem has been fixed. :dry: It would help us if you could post your configuration report (information about how to post your configuration report is in the posting guide that is printed at the top of this page).
Let's try to deal with one problem at a time. First of all, let's see the configuration report, then we might have better advice we can give you about what you need to fix that problem. ;)
14 years 9 months ago #118309 by sv8bur
Thank you very much here is my report
htaccess: Exists | PHP environment: Max execution time: 100 seconds | Max execution memory: 512M | Max file upload: 360M
Joomla default template details : boyshobbies | author: | version: 1.0 | creationdate: 2012-02-12
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Third-party components: CommunityBuilder 1.7.1 | UddeIm 2.6
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.7.2 | My Kunena Forum Menu 1.7.1 | My Kunena Forum Posts 1.7.1 | Kunena Groups 1.7.1
Modules: Kunena Latest 1.7.2 | Kunena Stats 1.7.2 | Kunena Login 1.7.2 | Kunena Search 1.7.0
Time to create page: 0.159 seconds
