Merged [Merged topic] "Remember me" issues
14 years 7 months ago #122567 by Nosferatu
What i need to post in configuration report? tell me plzz ill post :blush:
14 years 7 months ago #122793 by Nosferatu
Thanks for no support!Bye
14 years 7 months ago - 14 years 7 months ago #122805 by sozzled
Perhaps you did not see the FAQs menu tab above the forum where questions like "What I need to post in configuration report?" are answered. Please read What information should I include when I ask for help (including how to post my configuration report)?
Last edit: 14 years 7 months ago by sozzled.
14 years 6 months ago #123839 by Torchez
Hello.
And once again... "Remember me" still doesn't work. System - Cache disabled and all steps from post #4 was done.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 500M
Joomla default template details : new_architect | author: Shape5.com | version: 1.0 | creationdate: Novemeber 2008
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: CommunityBuilder 1.8 | UddeIm 2.1
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
Modules: Kunena Latest 1.7.2 | Kunena Stats 1.7.2
14 years 6 months ago #123865 by sozzled
sozzled wrote: (1) If you have it enabled, disabled System - Cache plugin
(2) Global Configuration » Cache Settings » Cache = No
(3) Global Configuration » Session Settings » Session Lifetime = 30 minutes (this should be quite adequate for most environments)
(4) Global Configuration » Session Settings » Session Handler = Database
You are also using a very old Joomla site template that is known to cause a lot of problems with many more "modern" Joomla extensions. We recommend that you do not use Joomla site templates with a creation date before June 2010, especially anything that introduces its own Javascript libraries. Have you tries using the Kunena Blue Eagle template that was designed for K 1.7.2 (instead of the one that you're using)?
Also see Search Engine Optimisation (SEO) and, possibly, check that the version of sh404SEF is compatible with K 1.7.2 or disable sh404SEF.
The following user(s) said Thank You: Torchez
14 years 6 months ago #124215 by Torchez
The first time I setted up 900 sec in Kunena-Itnegration (similar Joomla default session lifetime) and with this session time "remember me" not worked. And after that i'm left my post in this topic. When i set 30 minutes in both fields it worked. And while such work. Thank you.
Time to create page: 0.161 seconds
