16 years 2 months ago #58437 by blaaaaze
Has anyone solved this problem? I've been upgrading and downgrading back to 1.5 because the barcode is missing. Will be reverting once again.
The topic has been locked.
16 years 2 months ago #58454 by sozzled
It's solved. It all has to do with Mootools and whether or not your Joomla template is compatible with the latest Joomla Mootools Upgrade plugin. B)
16 years 2 months ago #58618 by blaaaaze
sozzled wrote: It's solved. It all has to do with Mootools and whether or not your Joomla template is compatible with the latest Joomla Mootools Upgrade plugin. B)
nice...would you or anyone be kind enough to name me on a template that works?
16 years 2 months ago - 16 years 2 months ago #58619 by fxstein
We have tried and are using several templates from RocketTheme that work perfectly fine. I believe they have also upgraded quite a few of them to leverage the latest mootools 1.2.x that now comes with Joomla.
Hopt this helps!
Last edit: 16 years 2 months ago by fxstein.
16 years 2 months ago #58622 by blaaaaze
fxstein wrote: We have tried and are using several templates from RocketTheme that work perfectly fine. I believe they have also upgraded quite a few of them to leverage the latest mootools 1.2.x that now comes with Joomla.
Hopt this helps!
Sorry it didn't. Need to know a specific template that works
16 years 2 months ago #58649 by blaaaaze
soumkhane wrote: i really like k1.6 i dont wanna use agora i like k1.6 so i hop you fix that problem and by the way i tried a lot of tamplate and still not work but tamplate of Shape5 its work fine but i cant changer what i have been working on my website so i have vox tamplate of yootheme . thank you for everything and thank for k 1.6 is free thank guys hop you fix it next time
did you have any luck? if so which template are you using?
Time to create page: 0.153 seconds
