Question [Resolved] Issues with attachments not showing in K 1.7
14 years 10 months ago #111231 by Sabby
I tried to do some searching on this issue I am having and foudn one post about a month ago that had no solution or answer. I just recent upgrade from 1.5 to 1.7. No attachments show in the forums, if you go to edit a post with an attachment you can see the text but when viewing the forum no attachment or link. I have tried the default template and even changed site templates with no luck. The attachments get uploaded no problem and I see them show up in media/attachments but the actual post shows only the text typed by the user with no attachment at all. Any ideas of what may be going on?
Thanks!
Site is www.fragaholics.net
14 years 10 months ago - 14 years 10 months ago #111232 by Sabby
Forogt the config, here it is.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : gored_ultra_lernvid.com-j1.6 | author: Juergen Koller | version: 1.0 | creationdate: Apr 2011
Kunena default template details : nts_kdark | author: 9ThemeStore | version: 1.7.0 | creationdate: 2011-05-07
Last edit: 14 years 10 months ago by rich.
14 years 10 months ago #111234 by sozzled
When you wrote that you recently upgraded from "1.5 to 1.7" did you mean Joomla or Kunena?
The following user(s) said Thank You: Sabby
14 years 10 months ago #111236 by Sabby
Let me clarify, I upgraded Kunena from 1.6 to 1.7.
Joomla from 1.5 to 1.7
14 years 10 months ago #111237 by sozzled
It's possible that jUpgrade (if that is how you did the migration from J! 1.5 to J! 1.7) broke the attachments. It would be good to know how you did the Joomla migration (what process/tool did you use).
Did you do the upgrade from K 1.6 to K 1.7 before or after you did the Joomla migration. Upgrading from K 1.6 to K 1.7 should not break attachments. Sometimes, when people upgrade from other forums or from older versions of Kunena or Fireboard, there can be breakages in the attachments, but that should not happen when going from K 1.6 to K 1.7.
It's possible that the table kunena_attachments is not right.
It's possible that there's a problem with the folder(s) in ../media/kunena/attachments
For each user (in K 1.6 or K 1.7) there should be a separate folder, for example:
../media/kunena/attachments/42
or maybe it's called
..../media/kunena/attachments/62
It's possible that jUpgrade did not change the folder names when it changed the user accounts.
14 years 10 months ago #111240 by Sabby
The attachments are working from an upload and data base standpoint.
When I add an attachment it saves the file in media,kunena,attachments as well as create a new record
in the data base.
Adding attachments works, it's just not showing them, if you edit the post you can see where lts supposed to be.
Time to create page: 0.343 seconds
