Question LightBox Enabled - But Clipping Images
Yes, I'm using the default Blue Eagle template, version 1.6.3...
The site runs Joomla 1.5.22, with a recent Yootheme template.
Please see for yourself: oudebenzclub.nl/forum (dutch site)
Hope there is a workaround:-)
Thanks for looking into it.
Best regards,
Pieter
By the way: forgot to tell that i love the forum component!
oudebenzclub.nl/forum/oude-benz-interieu...ng-b-stijl-vervangen
In Firefox, Chrome, Safari it works with a popup lightbox, but not in IE8. When I click on a message, I get online a white overlay, but no lightbox appears.
Regards,
Pieter
So, there is a conflict somwehere with your Joomla! template, you can check with the default Joomla! template.
I am having exactly the same problem.thesinger313 wrote: I have lightbox enabled on my website but when users click on the embedded image it chops most of the right side off.
Any Ideas?
Thanks in advance
Mikey
Have you managed to resolve this?
