Question LightBox Enabled - But Clipping Images
15 years 9 months ago #83420 by thesinger313
I have lightbox enabled on my website but when users click on the embedded image it chops most of the right side off.
Any Ideas?
Thanks in advance
Mikey
15 years 9 months ago #83443 by xillibit
update kunena to 1.6.2 version or search a template which use the new lightbox introduced in k1.6.2
15 years 9 months ago #83483 by thesinger313
Currently on 1.6.2
I'm pretty sure its not theme based as it does the same thing on every theme. Problem is all my users love the current theme so id hate to loose it. Is there any way of me updating or reinstalling the current lightbox?
Thanks.
15 years 9 months ago - 15 years 9 months ago #85290 by Mikote
I also I have this problem.
In version 1.6.1 it worked fine, but after upgrading to 1.6.3 this problem has appeared, but in my case, it is blank without displaying any of the image.
The template of the site and the forum used in both cases is the same with the version that worked fine (1.6.1) with which it does (1.6.3)
If I disable lightbox works fine with 1.6.3
any ideas?
Miguel
Madrid (Spain)
Last edit: 15 years 9 months ago by Mikote.
15 years 9 months ago - 15 years 9 months ago #85753 by Mikote
I found that causes the problem, in my case, it is blank without displaying any of the image with lightbox enabled, but not always, only if the file name contains spaces.
For some reason, Kunena 1.6.1 to upload images in the file name contains spaces, it removes them and saves them with such name.
As has been included in version 1.6.3 mediaboxadvanced, for some reason does not recognize those files that have spaces in the name.
The only solution I've found has been edited messages containing attachments with spaces in the name and change these names by removing the spaces, in addition to edit messages for calls to be correct the file renamed. This I have done with phpmyadmin in tables 'jos_kunena_attachment'and 'jos_kunena_messages_text'.
I hope that is useful for anyone with this problem.
Miguel
Madrid (Spain)
15 years 8 months ago #88139 by Pieter77
I have a ligtbox problem aswell.
I updated from 1.6.1. to 1.6.3.
The lightbox feature works fine in browsers like Safari, Firefox and Chrome... but not on InternetExplorer (8). In IE the only thing i see a a blanc screen overlay.
Any ideas how this is possible?
Regards, Pieter
