Idea Does JoomGallery IMG tags work in Kunena?
15 years 10 months ago #79630 by radekgorski
Hello all,
I have problem with inserting photos from JoomGallery (Version 1.5.6.1) to Kunena posts (Version 1.6.2).
Link looks like:
http://advpoland.com/index.php?view=image&format=raw&type=img&id=3642&option=com_joomgallery&Itemid=339
but no image is visible.
Could anyone help me to sovle this, please?
Thanks in advance,
Radek
15 years 10 months ago #79686 by sozzled
I cannot see anything with that link.
15 years 10 months ago - 15 years 10 months ago #79752 by radekgorski
I'm sorry, correct link is:
[IMG]http://advpoland.com/index.php?view=image&format=raw&type=img&id=3642&option=com_joomgallery&Itemid=339[/IMG]
Now I inserted that link into [code], because in normally pasted link, Kunena adds "amp;" (that's why you couldn't see anything):
Last edit: 15 years 10 months ago by radekgorski.
15 years 10 months ago #79786 by sozzled
15 years 10 months ago #79798 by radekgorski
Try now, pleaase (sorry, I forgot about user login)
15 years 10 months ago - 15 years 10 months ago #79802 by sozzled
Thank you. I wanted to try your image on this website (as I did in www.kunena.org/playground/main/66126-lor...t=10&start=190#79801 ) and, as I understand, it's not possible to use Kunena to post images with that kind of URL structure.
We've had this discussion before (see the results of this search ). I was aware that the functionality had been removed (for security reasons) from K 1.5 and I was aware that the development team had been looking at some proposals to allow JoomGallery images with K 1.6 but I was not sure what the current situation was. That's why I was insisting on seeing your example for myself.
You might find that some of the discussions that I referred you to, the results of the search, will help to better understand the situation with Kunena and JoomGallery but the best answer I can give you is this :
fxstein wrote: You are hitting a security barrier we have built into kunena.
The problem is that all browsers will perform a GET request on any URL placed inside of html < img > tags (and therefore coming from [ img ] tags).
In the case of a gallery this is the right thing to do, unfortunately hackers around the globe have learned to misuse this in various ways.
A very simple and none critical misuse would be to stick the url of the logout link into and [ img ] tag. Whenever somebody gets to look at that page, the logout would get executed. Now a logout is nothing extremely ugly, but you get the point, you can do a lot of other things.
Therefore Kunena performs a security check if the [ img ] tag truly contains an image file by looking at file name and extension.
I don't think that there's much we can do about this at present.
Last edit: 15 years 10 months ago by sozzled.
