Question Picture wont load
16 years 4 days ago - 16 years 4 days ago #70642 by eragon
Picture wont load was created by eragon
Hi All
One of my members as sent a picture that he cannot load on to the forum :(
He has sent the picture to me which I recieved ok :)
I tried loading picture on the forum and no show :(
One thing I have noticed is picture is not cached (does that make any difference)
Can someone please advise?
Thank You :)
Eragon
Last edit: 16 years 4 days ago by eragon.
16 years 4 days ago #70648 by xillibit
Replied by xillibit on topic Picture wont load
Do you have checked if the permissions are correct and if the file can be read ?
Can-you put please a report configuration report settings here ? Do you have a test account on your site ?
16 years 4 days ago #70661 by eragon
Replied by eragon on topic Picture wont load
Hello
What I have found out is the size of image being 3000 x 4000pixels would not load. :(
I reduced the image to 1500 x 200pixels and it will load and resize to suit forum. :)
The setting for the forum is 1000 x 1000pixels ;)
Configuration Report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 20M
Thank You
Eragon
16 years 4 days ago #70687 by sozzled
Replied by sozzled on topic Picture wont load
So you've found the cause of the problem and fixed it, right?
While I have your attention, I notice that you are still running Joomla 1.5 in "legacy mode". Please read the very important information about Legacy mode and take some action now to remove your dependence on it before it causes problems for you later.
16 years 3 days ago #70793 by teratyke
Replied by teratyke on topic Re: Picture wont load
Hi - assuming you haven't resolved this...
I had an issue on my site where just one image would fail to upload. It wasn't related to the file size or resolution of the image and seemed to consistently effect certain images.
The problem is now solved though and no problems since here is the thread...
www.kunena.org/forum/169-k-16-support-ar...d-failing-broken-css
Hope this helps
Rob
