Question Can not Access Forum Categories and Posts
16 years 1 week ago - 16 years 1 week ago #69954 by sozzled
Enes: You deleted the htaccess.txt file and your existing .htaccess file is probably botched-up! That's probably the problem. You should never delete files in the Joomla root directory unless you know exactly what you are doing. Have you deleted any other files there?
Here's my suggestion: Get the latest full stable installation kit of J! 1.5.22; extract the htaccess.txt file. Put that file back onto your website into the root folder.
This is what I would do next: take your .htaccess file (the one you are now using) and rename it to htaccess.bak. Then take you restored htaccess.txt file and rename it to .htaccess
Now try looking at your website again and let us know if that makes a difference. Please also read Search Engine Optimization (SEO)
Last edit: 16 years 1 week ago by sozzled.
16 years 1 week ago #69990 by artnco
hello, i have the same issue here, do you found a solution ?
thanks
15 years 11 months ago - 15 years 11 months ago #74236 by kanvishok
i think this issue is with kunena.
i have configured the my site as suggested in the seo document (wiki)
enabled the sef friendly, enabled the apache rewrite, disabled the suffix, in joomla
enabled the sef in Kunena.
my .htaccess is perfect. i didnt modify anything. no 3rdparty sef plugin installed.
when i click on the post link i am getting this redirect loop issue. any one can help?
thanks
Last edit: 15 years 11 months ago by kanvishok.
15 years 11 months ago #74237 by sozzled
G'day, kanvishok, and welcome to Kunena. I think your problem is quite different. Have you searched for "redirect loop" in the forum? Perhaps you have two (or more) menu items (with different targets) pointing to different instances of Kunena? Have you considered this possibility?
15 years 11 months ago #74238 by kanvishok
No i dont have 2 instances of Kunena.
kanbal.com/newkanbal/forum/recent
above is my url. i have freshly installed my site. no luck for me to resolve it. the issue is happening only when i click on the post link. all other menu links are working fine.
if possible please have a look on the link which sent.
thanks for your quick reply. waiting for your help to resolve this issue.
15 years 11 months ago #74239 by kanvishok
issue has been resolved. i have deleted the forum menu and recreated the menu. it works fine. Thanks.
Time to create page: 0.158 seconds
