Question [Merged topic] Index view shows some categories collapsed and others expanded
15 years 9 months ago #87085 by philiplardner
Is it possible to start Kunena with some or all of the information boxes minimised?
I would like to be able to start Kunena with the "Log-in", "Who is on-line" and "Statistics" sections closed or minimised, leaving just the Forums section expanded.
Thanks.
15 years 9 months ago #87147 by sozzled
Gday, Phil, and thank you for your question. Even though your question is a little different to similar ones that have been asked before, I have merged your topic with another one that might help to put matters into perspective for you.
Theoretically, anything is possible. However, there's always a cost associated with developing these ideas. To answer your question, I'm sure that this can be done, it just requires willpower (and possibly a bit of a financial incentive) for someone to make it happen. I'm sorry, I don't have a better answer for you at this time.
Short answer: no, this isn't a standard feature of Kunena at this time.
The following user(s) said Thank You: philiplardner
15 years 4 weeks ago #110205 by NOsen
Replied by NOsen on topic Expand Collapse view?
when you surf to the forum all the tabs are expanded for ea: login stats etc etc
can i set a default for the Expand Collapse view so that always are collapsed?
cheers!
15 years 4 weeks ago #110207 by sozzled
G'day, NOsen, and welcome to Kunena.
As you can see from this topic, the question has been asked before but, no, there is no mechanism to achieve it in the standard Kunena software at this time.
